theicemanhp
I have a HP zv6000 laptop with the Conexant AC97 audio board. I have Vista 64 Ulimate running on it and have spent hours trying to get the audio to work correctly. I have searched forum after forum and tried all the drivers people reccoment. Intel, ATI, Realtek, etc. I can get them to work in testing mode or by F8 but the sound quality i terrible, popping, cracking etc.
Now here is the problem I am hoping you guys can help with. I found the HP realtek drivers for XP64 SP30305.EXE that work without F* and without using testing mode. Now the strange part about them is if I start my computer and then install the drivers manually the sound comes on and works great. But when I restart the cimputer the next time I get a blue screen on vista loading with the "IRQ NOT LESS OR EQUAL" error and it restarts. Sometimes if I keep restarting it will eventually not bluescreen and will make it in to windows and work great but its not very convienant sitting there restarting for 20min to get it to work. If I go into safe mode and remove the drivers, restart and then install them once im in windows they work fine again aarrgghhhh!!!! Is there anything I can do to get thise working??
