Hi all
I have an HP Elitebook 8440p and it started showing the famous 'Plugged in, not charging message'. Well, the solution for this problem seems to be quite a simple one: uninstalling the 'Microsoft ACPI-Compliant Control Method Battery' driver and let Windows reinstall the driver. However, my system has 2 'Microsoft ACPI-Compliant Control Method Battery' drivers installed and when I delete both and let windows reinstall it I end up again with 2 of them and the battery issue persists. How can I prevent Windows from installing it twice? Thanks.
- Acer Aspire X3200
- 4GB
