Ricardo Verdi
I have an IVT bluenext BN01 micro bluetooth adaptor; I bought it in on amazon.co.uk 28 Oct 2010. It came with a mini-cd with bluesoleil software. I used it successfully for a while, but I haven't used it for a few months. It still works in my old XP computer, but I can't now get it to work on my vista laptop. It did work on this laptop before. A message on screen on the bluesoleil window says please insert a Bluetooth device. I have turned computer off & on again, taken adaptor out & put in again. Somehow windows is not recognising it. I presume it may be a driver problem but I may be wrong.
My Dell Vostro 1710 Vista laptop has automatic updates. Blue soleil is version 2.7.0.35. I uninstalled & then reinstalled this from the CD that came with the adaptor. The adaptor has no buttons on it, it's very small; the whole thing is less than twice the size of the USB plug itself.
Could I have removed the driver for it? I don't recall doing so. In Control Panel, Bluetooth Devices has nothing listed. If I click "Allow bluetooth devices to find this computer" then an error message says "An error occurred while windows was saving your settings. A Bluetooth device might be unplugged"
I've tried lots of things but it still doesn't work. Now a message says
BlueSoleil Bttray has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.(only one option - Close program)
and then
The procedure entry point FinishParse could not be located in the dynamic link library versit.dll
I've tried uninstalling other devices in device manager (some had exclamation marks, & wouldn't update the drivers when I tried) & deleting some bluetooth entries in registry (after backing it up).
I used USBDeview & uninstalled lots of unused USB devices listed there.
As far as I know my laptop doesn't have any integral bluetooth, so that's why I bought the dongle. And it worked.
Any other suggestions welcome!
and then
- Dell Vostro 1710
- intel Core2 duo cpu T5670 @ 1.8 GHz
- 4gb
