Driver compatibility between 32-bit and 64-bit
rhjoyson
I’ve just bought a new Win7 64-bit computer ... still in the box. I will be connecting via dial-up, and have bought Wintek’s external Filemate USB Modem CX ... which came with a mini-CD installation disk.
I’ve heard horror stories about mini-CD’s jamming vertical DVD/CD drives ... so, hoping to avoid using the mini-CD and jamming my new computer, I’ve downloaded the installation/driver file from the modem manufacturer onto a DVD ... via my old Vista 32-bit system. But the modem installation file is zipped ... so I can’t unzip/extract the .inf file and move it to my new computer ... without installing 7-Zip (or something similar) to my Vista system.
Bearing in mind that I can’t download anything to my new computer until I install the modem, will there be compatibility problems from moving a file which was downloaded/unzipped on a 32-bit system to a 64-bit system? Any other suggestions for installing my modem?
Thanks a million ...
Hello rhjoyson and welcome to the forums :party:
There won't be any problems if you unzip a file on a x86 system that you then go on to use in a x64 system :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I think the mini-CD problem is over-rated. I would just use it. If the drive gets jammed you can open it with a paper clip.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
