A required CD/DVD Drive device driver is missing
windows8
Power Abuser
Power User
Trying to install windows vista, but I get stuck at this point:
Select the Driver to be Installed:
A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now.
Note: If the windows installation media is in the CD/DVD drive, you can safely remove it for this step.
I click "okay' and then I have to browser for a driver to be installed, and I go to my folder on my desktop where I have my driver backups and it doesn't accept it.
    HP Pavilion G6
    750GB HDD 6GB RAM
    AMD A6-3400M APU with Radeon HD Graphics
    25mbps
Sounds maybe like a RAID driver.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I'm unsure of what a RAID driver is.. doesn't that have something to do with the hard drive?
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Yes for sure.
RAID is when you link 2 or 4 hard drives together, so as to either speed up readimng, or secure files.
RAID - Wikipedia, the free encyclopedia
the drivers will be found at your mobo manufactuers site
:sleepy: I'll keep that in mind. So all I have to do is download the RAID drivers and try again.
Thanks for the help. :)
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Allright, went passed that screen this time, and now its "completed" the installation, but its giving me a message saying "Windows Setup could not configure Windows to run on this computer's hardware."
Which is strange considering the SAME installation went through 100% just a few days ago.
Now it restarted and went past that screen, and it goes to the "starting windows" screen and from there it says something about "Setup starting services" (when i boot up PC) then gives me an error saying "Windows could not complete the installation. To install Windows on this computer, restart the installation"
I restarted the installation twice and it just installed 2 copies of upgraded windows, both of which give me the same error.
Running the windows memory diagnostics tool if it'll make any difference.
Allright.. first test passed.
Second test complete, now restarting for my results/
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Fixed it myself.
When prompted with error unable to complete installation:
Hit SHIFT-F10 to bring up command prompt.
type MMC
Click File -> Add/Remove Snap-in... (Or CTRL+M)
Select Computer Management (Double click and Finish on Local Computer)
Click OK
Double click Computer Management (Local) -> System Tools -> Local Users and Groups -> Users -> Double Click Administrator -> Uncheck Account is disabled -> OK
Now right click Administrator -> Set Password... -> Set a decent password to get started.
Now, restart. Should be good to go.
If this doesn't work try next step:
type: CD C:\windows\system32\oobe
type msoobe
enter
Make a generic account and password. hit finish (if it requests a product key and you have one, enter it now. if OEM/No key required, just finish). Set time/date. Finish.
Restart.
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
