Hey Guys
I bought one of the All in 1 HD docking station ( such as : http://www.szprice.com/product_images/o/a__01197.jpg ) and wanted to connect to my asus laptop running vista premium to recover data from 2 extenal hard drives. This external docking station came with a mini cd to install software which I did, however even after mucking around for hrs I am unable to view any external device in Device manager ! so I decided to plug in my iphone to test if this HD reader is faulty, however now it won't recognise iphone as well. I have already tried using all usb ports with no success
While looking for solutions online came across MS fix it centre - Microsoft Fix it Solution Center: troubleshooting software issues and ran a test. It came back with a few errors as below:
" Hardware and DevicesPublisher details
Issues found
Microsoft Tun Miniport Adapter #2 has a driver problemMicrosoft Tun
There is a problem with the driver for Microsoft Tun Miniport Adapter #2.
The driver needs to be reinstalled.Not fixed
Reinstall device driverSucceeded
ULi SATA II/RAID Controller (M1575/M1697) has a driver problemULi SATA
There is a problem with the driver for ULi SATA II/RAID Controller
(M1575/M1697). The driver needs to be reinstalled.Not fixed
Apple Mobile Device Ethernet #2 has a driver problemApple Mobile Device
There is a problem with the driver for Apple Mobile Device Ethernet #2.
Hardware changes might not have been detectedHardware changes might not
have been detectedDetected
Scan for recent hardware changesSucceeded
Issues checked
Windows Update configured to never install driversWindows Update
Driver updates aren't automatically installed when detected by Windows
Update.Checked
Issues foundDetection details
6Microsoft Tun Miniport Adapter #2 has a driver problemNot fixed
Adapter #2. Reinstalling the driver might fix this problem.
6ULi SATA II/RAID Controller (M1575/M1697) has a driver problemNot
fixed
(M1575/M1697). Reinstalling the driver might fix this problem.
6Apple Mobile Device Ethernet #2 has a driver problemNot fixed
6Hardware changes might not have been detectedDetected
Scanning might find new devices attached to your computer and
install them.
Issues checkedDetection details
6Windows Update configured to never install driversChecked
Update.
Change Windows Update settingsNot Run
Change Windows Update settings so that driver updates are downloaded
and installed automatically. "
Since the above makes no sense to me I was hoping to find help in this forum.
Help would be much appreciated on how to solve the problem and please try to keep your reply as simple as possible - minimal technical stuff
Thanks in advance
Sam
Issues found
Issues checked
Update.Checked
fixed
install them.
Update.
Thanks in advance
Sam
