Problems with Atheros wireless adapter drivers
I have an HP dv5-1002nr notebook PC from 2008 (piece of junk if you ask me, but that's another issue).
Way back when I first bought this computer, the wireless adapter driver would get corrupted every time the computer would overheat. At the time, I was shown how I could reinstall the Atheros wireless adapter driver from my Recovery Manager.
I have since solved all the overheating issues, but this morning, the Atheros driver disappeared (or was corrupted) again, and I have tried reinstalling it several times, both from the Recovery Manager and from the HP driver web site.
The files will load, and the installation wizard goes through, but then even after I reboot, the driver still doesn't show up in my network device manager settings, and the network wireless adapter still won't turn on.
HELP!!!!!
    HP Pavilion dv5-1002nr Entertainment Notebook PC
    AMD Turion X2 Dual-Core Mobile RM-70 2GHz
    3 GB
Hello and welcome thefourwinds , starting to sound like maybe a hardware issue here, are you still able to connect with it wired ? I am thinking hard ware issue based on the fact that you say the driver will not load up . However, have you tried uninstalling that driver and then reloading fresh one ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Thanks Yard Dog. Yes I can still connect with wired (as I've always been able to when I have this problem).
You are saying a hardware problem, but what hardware?
BTW, I know just enough about computers to be dangerous, so I often sound as if I know a lot more than I do.
Thanks for any help.
    3 GB
Although laptops are small and compressed, a driver is software that makes hardware perform as desired, that being said, there is hardware that controls the wireless connection. Try going to your Device Manager and open the Network Adapter up by pressing the plus sign , for the wireless, just go ahead and uninstall the wireless driver , then try to reinstall the new one.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
But that's just the issue. When this happens, the wireless completely disappears from the Network Adapter info in the device manager. I've been reinstalling all morning, and it's not working.
That's why I was curious what hardware you thought might be the problem.
    3 GB
Meaning, I've been reinstalling, but it never reappears in the device manager.
    3 GB
Rut roh, that is not good at all, you may have to have that rascal checked out by a repair shop, unless someone else here has any ideas for you.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Go to Speccy and get the free program and see if it even shows it : Speccy - Download Just get the free program . Take a look at what it finds.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Ha, I downloaded Speccy, then when it was running, it said a problem occurred, and Windows shut down the program.
    3 GB
Wow, may be other hardware affected from the overheating issues you had . Do you ever get any beeps at startup , other than the normal start up beep ? Speccy scans your hardware installed on your computer and when done , shows what you have, give it another try at running .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
