flashed blue screen with driver power state failure
could this be due to having three hard drives on the same power cord?
if so thats an easy fix
also its a fresh install in raid 0 config, ima check for more updates now.
possible missing drivers or power problem power supply should be more then effecient.
- home built
- AMD Athlon 64 X2 4200+
- asus m2a-vm
- 2 gigs kingston hyperx
- geforce 9800 gtx/gtx+
- n/a
- samsung led 23 inch
- 1280 x 1024
- Two western digital raptor 1005 gb in raid 0 1 tb caveliar black wester digital
- PSU
- 1000 watt modular by ultra i belive.
- Case
- apevia
- Cooling
- 6 fans
- g500 logitech
- g15 logitech
- cable
