Solved need a lil help opening and installin driver
jasond19
Power User
can any1 explain to me how to install a updated driver? i downloaded a driver that is compatible with the one that i needed, (my speccs dont apply dont apply im on a toshiba laptop) drivers foe the network adapter needed updated, atheros comunicaton:ar5006eg.164 the new ones number is 5007eg, im pretty sure i searched and found the correct one, if u wouldnt mind double checking id ty, came in a zipped file, that needed to be opened with windows powershell, i i couldnt seem to get the file open. any help would appreciated.
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
I am not sure where to guide you to get the downloads for your make & model. The information you have provided is in conflict: -
If you need any further assistance please post the full details for make & model number for your PC.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
toshibaOperating System
MS Windows Vista Home Premium 32-bit SP2
Intel Pentium T2080 @ 1.73GHz 62 °C
RAM
1.0GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
Graphics
Generic PnP Monitor @ 1440x900
Mobile Intel(R) 945 Express Chipset Family
117GB TOSHIBA TOSHIBA MK1237GSX ATA Device (SATA) 39 °C
Optical Drives
PIONEER DVD-RW DVR-K17LF ATA Device
Audio
High Definition Audio Device, sry about that, i thought i put that on there,
    toshiba satellite
says to open the zipped file using windows power shell, but it wont let me, i think im missing something,
    toshiba satellite
Go to help and support, by start menu.
Then type zip
Follow instructions
went to help and support typed zip, but didnt find how to open
    toshiba satellite
ok i followed them instructions and when i doubled clicked the file a window pop up kinda looks like the command prompt window, has red letters in it, but it wont stay up long enough for me to read it just closes
    toshiba satellite
Go back to the website and look for instuctions how to open the zip. You may need special zip software. I dont know.
The zip that you used should have opened it.
Go to the website and download once more to your desktop and try to open it.
i went back and redownloaded tryd to open and the same thing, what program should i use to open? it says windows power shell...
    toshiba satellite
This is a first for me, zip always worked, but here you go
How to Download Windows PowerShell 1.0
Start with a system restore point, I have no idea of what will happen when you download.
    LENOVO 64734VM
    15 inch
