learning2fly
Hello, this is the first time I'm posting something like this to a forum like this and first time I ever had an issue like this.
I attached a picture of the issue.
I was told that it might be the video card/graphics card. Is there a way to fix this issue or do I have to buy a new video/graphics card? Or is it the screen itself?
What happened was i was just browsing the internet, then my screen started to flash and then the blue screen appeared and shut down. I tried fixing the resolution back to 32bit, since its at 4bit and it wouldn't change it back... it stays at 4bit. There's also a vertical black strip on the right side of the screen, as you can tell on the picture i attached. I think it's also crashing my firefox, since its done it numerous of times. I have a HP Pavillion dv6000, windows vista home premium. If you need more info on my laptop, I can find it and let you know. Thanks in advance!
