Problems with Bluetooth driver?
This should help.
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
or much easier way, but maybe not the best driver
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
This should help.
How to Find Drivers
Device Manager - Finding Unknown Devices - Windows 7 Forums
I'm really not sure dude.
I did one of the things you told me and i found this.
http://img248.imageshack.us/img248/9208/134452414.jpg
So thats basically my Hardware ID and all that crap, but i really need your help to find these 'drivers' or whatever they want me to install cause i have no disc..
All i really know is that i need ZTE drivers or some ****, i really have no clue.
I just found a zip file of some sort of ZTE driver but it didnt work.
You can use this method for the driver
Driver Install - Device Manager - Windows 7 Forums
If you are goint to the website and prefer that method you can try to download to the desktop and install from there. Choose save when at the website
You can try to install in safe mode
Be sure it is the correct driver.
