wifi card wont power on
nelizmastr
my computer has a Sweex LW057 / marvell libertas 8335 wifi card, which has built-in Vista drivers.
thats fine, but the device itself wont power on.
when I boot into XP, it works just fine. it seems to be an issue between the BIOS/Motherboard and the PCI slots.
BIOS = AMIBIOS dated somewhere in 2006 (rev 0211)
could anyone help me? Im wanting to install Premium or Basic on this.
    Maxdata
    AMD Athlon 64 3200+
    ASUS A8V-MX/SI
    1GB DDR400
    Powercolor Radeon HD3650
    ALC653 AC'97
    Dell 1703FP
    1280x1024x32
    Maxtor 80GB 7200rpm IDE
    Q-Tec 300W
    some white-ish metal and plastic one
    80mm 4000rpm chassis fan, CPU fan
    toshiba optical
    a black one
    60mbps (but only gets 10-15mbps through wireless)
    no flaming
