When I last started up my computer I had an error saying it wouldn't start up properly, and gave me the option to either use System recovery or start up normally. I used system recovery and it loaded the files, then it went to a blue screen and now says 'select an operating system to repair and click next. Only windows vista operating systems are listed and can be repaired'. 'If you do not see your operating system listed click Load Drivers to load drivers for your hard disks'.
Nothing is listed. What do I do here? I have a recovery disc but it isn't for my computer, so I'm not sure if it'll work for mine.
Can anyone help? Thank you.
