Hiya, I wonder if anyone can help me, I have a BT multijet 3000 printer which worked fine on XP, but when upgraded to vista says unrecognised device, the driver isnt in vista, the cd which accompanied the printer doesnt work, and the company stopped support for the printer before vista came out, I wonder if anyone can help me to find the driver or tell me how to set up a generic printer so it can at least print documents, I tried the generic ones on vista xps and image one, but they didnt work, any way of how to set up the port manually, its USB, and there is no option for usb, just says lpt1 or com ports on the xps one
Help! Thanks
Help! Thanks
