Power State Drive Failure and Blue Screen
Hot Rod Todd
I know this has been a much discussed topic evident by the many results I have found. My Gateway computer is also having this problem. It seemed to be getting more frequent so I took some of the advice here and updated my graphics driver (ATI Radeon HD 4850 series). This computer is only a few months old. Here is the most recent minidump file. Thanks in advance for any help decoding this error. Todd
Hello Hot Rod Todd,
This was caused by "sbp2port.sys", do you have any firewire bits on your PC, an ipod, or camera ?.
This sbp2port.sys works with the 1394 storage support, so if you have any devices connected to your PC, disconnect them and try it, if all goes well, you will need to update your drivers.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
The only firewire device I have is a Seagate external hard drive. I have it disconnected most of the time but I will leave it and see how it goes. I guess I need to update the Seagate driver. Thanks for the tip.
