Catalyst control center uninstall problem
Larry D
Power User
Hello, I am upgrading to W7. I need to remove Catalyst Control Center prior to the upgrade. When i try to uninstall the program i get setup.exe stopped working. Can anyone help? Thanks
    Dell xps420
    quad [email protected] Ghz
    BTX otp406
    4 gig @ 800mhz
    ati radeon hd 2600 xt PCI-E 256MB
    PCI Express X-Fi Xtreme Audio
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
    Download 2.8 mps Upload 722kbps
    Nod32 4/ Logitech z5500 5.1/ Canon mp600 printer
Wipe your PC, do a clean install and then install Catalyst. Why do you need to remove it?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Hello Frostmourne, The W7 install disk requested the removal,although when i ran the W7 advisor it did not mention it. I was able to remove it with revo uninstaller thru the reg. Thanks for the reply.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
