How do I fix problem with no mouse or keyboard?
ssmr
I need some help! I can't get my mouse or my keyboard to work (in any way, including function keys during bootup) I have tried other keyboards and a mouse and the problem is clearly with the computer. I'm guessing one of my four kids erased the driver software, but I don't know how to do a system recovery or download new drivers, or anything else when I have no keyboard and no mouse function to allow me to control the computer. I need this computer to do a grad school assignment and am desperate for some help. THanks!
Hello ssmr,
Try and unplug the keyboard and mouse and then reboot, plug them back in, put them in different usb sockets and if necessary reboot, your system should load new drivers when you reboot.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
is your mouse and keyboard USB? is USB keyboard support enabled in bios? (not that you can enable it anyway with no keyboard ;) )
if thats the case buying a cheap PS2 keyboard will get you out the mire
yuo might also wanna check that your usb ports aint been disabled in bios or in device manager (with a ps2 keyboard ;) )
you dont need drivers on your os for basic keyboard usage btw
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
