Java issues - keeps saying problems...
soulman1015
I have been trying over and over again to figure out what is going on with the Java install.
I install it with out a problem, then it says that "Java Runtime Environment has experienced a problem and will be shutdown.." and also that windows will let me know if there is any fix, however this has been happening for almost 3 weeks now, and nothing.
I can't do a lot without it, as quite a few of my programs use Java.
Can someone help?
I'm running Vista Home Premium 32 bit, and Firefox's latest version...
These are all Java add-on you need for FF ..:
    S-Vaio FZ
    Intel Core2duo T7100-1.8GHz
    DDR2-2GB-PC2.5300-Sp.667MHz
    Mobile Intel Graphics Media Accelerator X3100-358MBvideo ram
    200GB/7200Rpm/Serial ATA
Thank you. I will work on installing them soon...
Next issue is this - for some reason, the "User Account Control" keeps turning itself off. I then log on in the administrator account to turn it back on, restart, and everything is fine for about an hour, then it happens again. I have run my AV (I have Vipre) in the deepest scan it has, and removed any issues, but it keeps happening... can you help with this?
Can someone help?
If you don't mind trying this beta version of Java7,give it a try by uninstalling all previous versions and installing this.
I have been using this a couple of weeks now and I haven't had any problems with it but it's your call. HTH.
https://cds.sun.com/is-bin/INTERSHO...uctRef=jre-7-ea-b66-oth-JPR@CDS-CDS_Developer
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
