problem in running exe files from CD drive
Deepa
I'm using windows vista home premium. I cannot run .exe files from my CD drive. when i trying to run .exe file. i'm getting this error
"Windows cannot access the specified device,path or file.you may not have the appropriate permissions to access the item."
I loged in as administrator. but i can execute .exe files from other folders.I'm having this problem for past 2 months. pls give me solution for this problem.:(
One thing that may be happening here is that depending on what the .exe is trying to do it may be trying to create a file in the same folder that it is running in. If a program attepts this on a non writable medium such as a CD it will produce this generic error message. if you copy the .exe to the hard drive does this then run?
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
