Video Hardware problem with my SONY VAIO
Morris44
I have a Sony VAIO which I purchased 14 months ago. It has been running warm for a while now until last month it would not start up. When you switch on you get a page of letter a' s then a blue and black vertical striped page then nothing.
The Start up repair will not work.
It took a while but finally I got a response on the Problem Solutions from Microsoft suggesting that there was a problem in that there was a 'video hardware error'.
It has since said there is also a problem with the 6-4 adaptor.
I did try to download a driver update however it says that it can't recognise the software and will not complete.
I have run a registry scan and it found hundreds of problems with Reg Cure however it woill not let me actually make the purchase so that I can get unlimited fixes.
The model is VGN-S71 E
reg cure wont help , its not a reg issue , either way reg cure still wont help its a waste of cash dont buy it mate trust me. 100% of the "issues" it found wont actually be issues at all , just redundent reg keys which are no problem and never will be.
it seems you have a hardware issue and your only resolution is an RMA (return to manufacturer) or a repair shop (is it still under warranty?) a repair shop will be expensive and most likely a waste of time.
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
