When I first connected my iPod to Vista it installed the "necessary software" but later stopped working. When I restarted the computer, the drivers wouldn't install. I tried it in different USB ports and finally got it working, except now when I connect the iPod I get "there may be a problem with this device. Scan (recommended) or continue without scanning. I close this box and the iPod seems to work fine, but this error message consistently appears. I did have a flash drive installed and it seems that the iPod drive is now the same drive letter as the flash drive was. Could this be the cause of my problem, and if so how do I fix it?
Thanks.
Dave Ward
Thanks.
Dave Ward
