I have problem starting up Vista - problem with driver
Tomassuver
Hey there,
about a week ago i installed Windiws Vista Business. i noticed a couple of times that my [COLOR=#3676a2! important][COLOR=#3676a2! important]PC[/COLOR][/COLOR] jusr restarted itself. other than that it worked fine up until last night. it all started with intenet explorer. i couldn't open any [COLOR=#3676a2! important][COLOR=#3676a2! important]website[/COLOR][/COLOR]. it said something about corrupted file. so i figured i'll give it a restart. and then the it wouldn;t boot up anymore. it says that windows failed to start.... then it says:
file \WINDOWS\SYSTEM32\[COLOR=#3676a2! important][COLOR=#3676a2! important]DRIVERS[/COLOR][/COLOR]\acpi.sys
status 0xc000000F
windows failed to start because a critical system driver is missing, or corrupt.
i already tried to do what it said there. it told me to put in the original CD of vista and click on repair. well that didnt work. it was repairing over 18 hours and nothing is happening.
any suggestions? plz if u could help me i would really appreciate it, i have all my work, school stuff = pix on the harddrive i wouldnt want to loose that.
thanks
Tom
Sounds similar to an old xp thing with the acpi have you tried loading to a safe dos mode and running checkdisk with the appropriate parameters I think its "checkdisk /f /p" you'd need to run "checkdisk /?" just to make sure.
    HP HDX 16-1010ea
    Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26Ghz (2 CPUs) ~2.3GHz
    4096MB RAM
    NVIDIA GeForce 9600GT
    Dolby Home Theater
    16.4" Built-in Laptop Display
    1920*1080
    Internal HDD 320GB External HDD [WD Portable 320GB] External HDD [Maxtor 500GB]
    Logitech VX Revolution
    onboard
    6MB Fibre Optic Broadband
    Blu-Ray/DVDRWDL/CDRW/LightScribe, Akasa Assisted Cooling Plate Laptop Gaming/Developer Power-User
