Display driver nvlddmkm stopped responding! help big problem!
fields999
Hi
I was recently playing gta4, as i have been doing for months now, and its all been fine.
But today for some reason the screen went blank for a few seconds and a popup on the startbar said that the display driver nvlddmkm stopped responding and has been recovered successfully.
Ive seen loads of posts and stuff about this problem and loads of people have it, is there any actual fix or is this then end?! Its happening all the time now, and i havent installed any updates lately compared to when it used to work fine.
please help, thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
The band-Aid or work around for me was to install Dedicated x64 drivers for my monitor... add that to the hotfixes on that site ;)
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
as neither NVidia nor Microsoft will accept responsibility for the issue it'll never get fixed , thousands and thousands are affected with it as you have seen , i had it a while pre SP1 but it just went away on its own
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
