About three months ago, the mouse to my laptop stopped working. Shortly thereafter my iPod stopped being detected in my itunes and, thus, stopped syncing. iMy computer makes the noise that it has detected a USB device when i plug my ipod into the computer, but my iPod doesnt show up in the iTunes menu. I assume there are problems with the USB in that regard.
Also I bought Lord of the Rings Online and installed it with no problems, but when I went to play it, it wouldn't load up and was giving me error messages. Now when I click play, it doesn't do anything.. nothing loads at all.
So when I go to control panel >> hardware there are those "exclamation point in the yellow triangle" symbols next to the NVIDIA GeForce Go 6150, and also next to the Standard OpenHCD USB Host Controller.
I took it to Geek Squad (who held it for nearly a month and a half trying to fix it, only to find out that it was a software issue after replacing the motherboard... this software issue was determined to not be covered by my warranty -_-) and they suggested that it was a corrupt OS and that i should uninstall my OS and reinstall and reformat OS (they were also going to charge me 130$ for this service).
I was wondering if anyone has any suggestions on what to do. I have a HP Pavilion dv6000. Thanks a lot.
