this post was a year ago with no solutions but i am having the same problems:
i have done the same thing and am having the same problem on my hp tx1219us laptop
every time i try to adjust volume with the hard keys it doesnt work and i have to restart explorer.exe to make it work, half the time doing that doesnt help either. i have to fully restart my pc. system restore wont work because the problem is percistent and has been around for over 90 days, i dont want to do a full restart of my pc as i have done it before and encountered the same problem again, i ran sfc and it gave me this:
Windows Resource Protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
C:\Windows\Logs\CBS\CBS.log
C:\Windows\system32>windir\logs\cbs\cbs.log
The system cannot find the path specified.
i dont want to do a full restart of my pc, any suggestions would be appreciated. i have a hunch that it might be my driver? idk
thanks
p.s. vista home premium 32bit with all windows updates
Hello. My windows explorer is constantly freezing! It wont let me change the volume or battery settings. I go to change the volume and it doesnt go up, so then I click on the taskbar and it shows the hour glass and then a message pops up saying "Windows Explorer is not responding" and this happens to me all the time. Any suggestions?
thanks
