Problem with hard drive after installing it on vista!
fields999
Hi
Recently i bought a 500gb internal hard drive to put in my computer, it already has one 500gb hdd.
I attached it all and its working fine apart from, sometimes it will make a weird scraping noise and im not sure why, it stops after a while. Its only new so i dont know if it will get worse or anything.
The thing is i tryed it in my old pc of windows vista 32bit, and its fine. But for some reason on this new pc it makes a scraping noise occasionally.
Does anyone know why this is happening? Is there something i need to install for it?
Thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
it sounds defective. i would rma it. the noise you hear could be the read/write head coming in contact with the platters.
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
Hmm well i reformatted the drive, as its an extra drive that didnt have any data on it yet. Then i used the windows check disk utility on it.
So far it hasnt made the grinding noise again and im hoping it wont. Not quite sure what was happening as its been fine for quite a while on my 32bit vista machine, then when i installed it on the 64bit vista i had the problem.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
I notice that you have 300w power supply, which for your spec is not high. Hard drive noise can be caused by an over stretched PSU.
    Self Build
    Intel Quad Core QX6700 4 X 2.66M
    ASUS Striker II Extreme
    4 GB DDR3 1600
    Nvidia 8800GTX 768MB PCI-E
    SoundMax
    2 Flat screen 21" LG displays
    5 internal Hard Drives: 2 x WD 500GB (CAVIAR BLACK 500GB 32MB 7200 SATA) 3 x WD 1TB (CAVIAR BLACK 1TB 32MB 7200 SATA) as Raid 5 array
    Tagan TG 1100W TURBOJET QUAD SLI
    Thermaltake EUREKA Case - Black
    ASUS V60 Quiet with additional fans for H/drives
    Logitech G7
    Logitech G15 Gaming
    0.5 Mb - (Benefits of rural location!)
    Teaming 2 GB network connection to Wired 1GB switch. Connected to 22TB (Raid 5) of network storage on a wired 1GB lan. (Mixture of internal hard drives, 1TB, 2TB & 4TB Terastations)
ok thanks, ive orderd a new 520-600w cooler master so that should be good for it.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
