CD/DVD writer/reader problem!
Mrtyn
I have a Acer Aspire 6920 that doesn't read nor burn dvd or cd's anymore because the Slimtype DVD A DS8A1P ATA software is missing from my notebook (code 39)
So I was wondering if anybody could help me fix this problem so my notebook can read cd/dvd's again.
thanks
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
@ Mrtyn, try these procedures here - You can no longer access the CD drive or the DVD drive, or you receive an error message after you remove a CD recording program or a DVD recording program in Windows XP: "error code 31" - It "might" fix your problem. Yes these procedures work on Vista.
@kword88, What's up with website you're linking to??? I'm always suspicious when a site I attempt to open tries to install software before allowing me to see the site; especially when IE blocks the site! :eek:
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
@sygnus21
thanks for your reply, but I'm not really a computer genius
So I don't think I want to try the Registry Editor because of the warning.
I think I'm going to call Acer today so see if they can do anything to help me,
because I really can't think of simple solution for my problem.
But really, thanks anyway.
WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system.
Microsoft cannot guarantee that problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk
