d3drm.dll problems
i found this in another forum, so i cant say if it will work or not.
http://www.dlldump.com/download-dll-files_new.php/dllfiles/D/d3drm.dll/5.1.2600.0/download.html
When you start, just download it to the desktop (this is what I did), then open my computer, and type
C:\Windows\System32, and press enter. The screen may display a different address, that is ok. If you are in the right place, if you scrol down a little you should see several other files ending in .dll. If you do, then just drag and drop the file you just downloaded onto the desktop anywhere in this folder. Now try the game.​
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
This is x32 module and @corman221 has x64 system,he should place this file in C:\Windows\SYSWOW64 where x64 system store x32 modules,otherwise it won't work
