You should upgrade or use an
alternative browser .
Solved Wireless Mouse & Keyboard problems
My wireless mouse and keyboard no longer work. The mouse stoped working six mounths ago, and the keyboard a few days ago. I put in new batteries and read a couple of post on this forum. There are 5 listings under keyboards and thay all show to be working properly. There are 3 mouse and all show to be working properly. Any suggestions please. I am running vista 32 bite.
re: Wireless Mouse & Keyboard problems
Hello Dterry,
See if uninstalling all of the extra keyboard and mouse devices listed, then reinstall the drivers for your current keyboard and mouse may help. You should only have one device listed for each one if those are the only ones you are using.
http://www.vistax64.com/tutorials/171469-uninstall-device-device-driver.html
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thank You!!
You're welcome Dterry.
Operating System
Operating System
