Need help pci wireless card code 31
needhelp2009
Ok I have a Infosmart INWP18G [FONT=Arial, Helvetica, sans-serif]802.11g 108Mbps Wireless LAN PCI Adapter
[/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT]
[FONT=Arial, Helvetica, sans-serif]I just got a new computer I built my self. on my windows 88 pc this card worked fine. on my other vista home prenium cd the drivers loaded up fine, on this computer I just bought I get code 31 and It does not want to work, on this pc i downloaded the drivers for windows vista hoping that would work and it did not, can some one help me fix this I have run out of ideas on how to fix it.[/FONT]
[/FONT]
That code is saying windows can't find a working driver. You may need to do a manual install/update. In device manager locate the adapter -
- Right click it
- Choose Properties
- Click the Driver tab and
- Choose “Update Driver”
When asked “How do you want to search for software driver” - choose “Search automatically for updated driver software” – if found Windows will install the driver.
If that doesn’t work –
Choose “Browse my computer for software driver” and locate the folder where the adapter contents have been extracted, or, if you have a disk or CD, point to it and let Windows do the install.
Hopefully will get you up and running.
Let us know.
Good luck
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
- Right click it
- Choose Properties
Let us know.
Good luck
I have done this i installed every driver on the cd manually, and every driver i can possably download from the net and nothing i still get the error is there any other way to fix this?
Shutdown, pull the card out, reboot, shutdown, reinstall the card, reboot, do a manual driver install. If that doesn't work, then either the card is bad, or those drivers are not Vista compatible.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
