Uninstalling nvidia geforce driver problem
hahallur
Hi
I just removed driver 181.20 from the "Remove Programs and Features" app.
After rebooting there is still a nvidia display driver running but now it says it's 180.48 which I previously had.
Now this wouldn't be an issue if I would still se the driver in "Remove Programs and Features" but I don't.
So any help out there ?
Regards Bourne
Did you also uninstalled the PhysX driver that comes with any of the 180 drivers? Use the driver sweeper after rebooting.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Hi
Regards Bourne
Hi Bourne, try this:
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
remove all applications related to nvidia.;)
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Could it be that, somehow, you just "RollBack" to the previous driver and not Uninstalled? I have never seen than before.
What I would do is install (as admin of course) the 181 series drivers, reboot, and then, uninstall again, only this time, uninstall the drivers first, do not reboot, then, uninstall the PhysX drivers, reboot, use CCcleaner to get rid of the registry remants of the driver and see what happens. If you go to Device Manager and find the generic vga driver, you are good to go with a clean install of what ever driver you want.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
I used driver sweeper and was able to remove the drivers.
Now I'm running "Registry cleaner" and It's taking it's sweet time ... few hours running now... is that normal ?
Few hours? I am going to have to say NO!
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
