les korcala
Hello,
I am new to this group and hope someone could help me.
Two nights ago we had power outtage ( eventually we had no electricty for 12 hrs)
my computer just shut off , I smelled something burned right away.
After taking out the power supply I smelled again and it was PS toasted.
Went to Fry's and replaced it with a better unit, put it back together and turned PC on great! everything was on: fans, lights, dvd would open etc..
The problem is that it doesn't boot. I tried to reboot with original software Ultimate. I tried to use the repair function, but it gets stuck looking for drivers. I tried to reinstall Vista but it won't let me do it either. The message says to locate drivers but I can not locate them. The hard drive manufacturer claims that Vista has the right drivers.
I build and it ran flawlessly for 8 months until the power outtage. The computer is build from part that I purchased at Fry's.
Any ideas about the driver problem? Is there any way to avoid re-installing Vista?
Thank you so much for any tips you might have.
Les
Les
