I think this is classed as a driver problem?
astrofighter
Hi all, sorry im new here, and just very stressed..
My other half has gone to work and took my laptop to work, leaving me with his.. Its an Acer aspire 5920.. He has very little understanding of computers, and as he rushed out of the door, held the power button to turn it of.. Now its sat on my desk feeling very poorly..
When i turn it on its a black screen saying:
"windows failed to start. a recent hardware or software change might be the cause."
It gives me 2 options.
1. launch startup repair,
2. start windows normally..
When i click to start startup repair it loads the green vista loading bar, and background which all looks very promising! WRONG!! It then says 'system recovery options' select a keyboard layout. I set it to 'united kingdom extended', then click next.. It says to select an operating system to repair, and click next. only windows vista operating systems are listed and can be repaired. (Nothing is listed). Below it says "if you do not see your operating system listed, click load drivers to load drivers for your hard disks"
Ive tried this on near enough every single file i can find, and none of them work.. It re-starts and takes me back to square one..
If i dont load drivers, and click 'next' it takes me to a screen where i can (or should be able) to chose from:
startup repair (takes me back a step)
system repair - that says there are no restore points,
windows complete pc restore- which doesnt open
windows memory diagnostic tool- which takes me right back to the beginning
command prompt.
Clicking starting windows normally:
A brief blue streen, saying i have an error, which gives me no time to read, then restarts p.c and takes me back to scratch..
Pressing F8 on startup gives me loads of options, none of which work.. Including trying to start up safe mode..
To make things worse, its not my laptop, and i want to try and avoid formatting the hard drive, not only because i don not wish to lose everything, but because recovery disks were never made..
PLEEEEEEEEASE help. ill make a donation.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
There is probably a key press instead of F8 - could be F10 or F11,
to start the recovery program on your recovery partition (check the manual )- this would erase your data, though.
You might try this free program
EASEUS Disk Copy: Free Disk Copy, Disk Clone, Partition Copy Software. Sector by Sector for hard drive backup freeware.
Getting Started -Create a Bootable CD/DVD- Easeus Disk Copy Manual
Getting Started -Boot From CD/DVD- Easeus Disk Copy Manual
Hope it helps
SIW2
Will i be able to make a recovery cd, even if i cannot turn the computer on?
Negative - you'll need the computer booting in order to do that.
The bad news is that, since it is not showing a Vista installation, you're quite possibly out of luck....the good news is that perhaps the recovery you're attempting is in and of itself hosed. If you can, borrow a windows installation disc from someone and see if you cannot use the recovery system on the disc to see your Vista install - if it sees it then you may have hope after all.
BTW, if your other half used the power button by holding it to power off the laptop then that is bad - but if he pressed it for a second or so, then it should have initiated a shutdown sequence much in the same way as you would manually do it from the start menu thus no harm nor foul.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Just to follow up on John's post - it's certainly worth trying the repair options on a proper Vista dvd - if you can get hold of one.
Otherwise, it's likely Acer will send you "recovery" media for a nominal fee, but if you use that, you will lose your data.
If you can't get hold of a dvd, you can create one that gives you those repair options by following option 1 in this tutorial :
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
With any luck, the automatic startup repair on the dvd (or the disc you created from the tutorial ) will do the job.
If not, you could try the command line options from the dvd (or the disc you created ) as shown in this tutorial:
Recovering the Vista Bootloader from the DVD - NeoSmart Technologies Wiki
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
