Need help desperately, Unknown devices problem
lempkema
So one day I turned on my computer from a hibernation, and the windows didn't resume correctly, so i dumped the restore and just rebooted. Following that, none of my usb devices worked. In my device manager, under Universal Serial Bus controllers, there are two unknown devices (I uploaded a picture).
I've looked all over microsoft support for an update that would help, and I couldn't find anything. PLEASE HELP!! I NEED MY FLASH DRIVE FOR COLLEGE!!
Download a program called DriverMax. There is a free trial for this. This program has an "Unknown Devices identifier" and is very easy to use
DriverMax looks promising and it is free. Thanks
    Home Built
    Intel Core 2 Quad Q6600 Kentsfield
    GIGABYTE GA-EP35C-DS3R
    OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
    SAPPHIRE 100242L Radeon HD 4850 512MB 256-bit GDDR3 PCI Expr
    On Board
    Acer B223Wbdmr Black 22" 5ms Widescreen LCD Monitor with Height & Pivot Adjustment 300 cd/m2 2500:1
    Western Digital Raptor X WD1500AHFD 150GB 10000 RPM 16MB Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM 16MB
    Antec NeoPower 650 Blue 650W ATX12V / EPS12V SLI Certified C
    Antec Twelve Hundred Black ATX Full Tower Computer Case
    9 different Optical Drives installed for review purposes
probably a registry error. If drivermax doesn't work, try a repair install.
    E8400
    asus p5ql-e
    ocz pc 1066 2x2gb
    asus eah3650 silent
    Edirol UA-25
    Gateway FPD2185W
    1680 x 1050
    750g samsung
    Zalman ZM460B 460W
    Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
    Coolermaster Hyper Z600 fanless CPU cooler
    Microsoft Laser Mouse 6000
    Merc Stealth
    DSL
