I NEED help with Printer Spooler Error
SlickNick
Ok I have a desktop computer that is hooked up to an hp printer. I want to be able to use the printer through my wireless network on my laptop which has Vista Home Premium 32bit. I have researched the problem on the internet and have done a bunch of things that people in other forums have suggested. I have uninstalled adobe acrobat, I have have checked the dependencies and the spooler depends on the LexBce Server. I have the spooler set to automatic, I have all the failure taps set to the "Restart the Service" selection and the next two spaces set to 1. If I try to start the spooler I get error 1068: The dependency service or group failed to start. Since the LexBce Server is not running, when I try to start it, I get Error 2: The System cannot find the file specified. I think it can't find it because I think I did something in Command Prompt that somebody suggested. I think I deleted it or something. Is there ANY way I can completely wipe out the LexBce server and take it off the Spooler's dependencies list? Any other suggestions? Thanks a lot.
Hi, SlickNick, and welcome to the forums.
It sounds like the machine used to have a LexMark printer attached to it at one time or another (Some Dell printers are made by LexMark as well).
Over at Bleeping Computer I found this little gem that should help you out: LexBce Server
HTH
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
HTH
I've already used the command prompt sc config spooler depend= RPCSS. I forgot to mention it in the original post. It tells me access denied. Know how to gain access?
you need to run CMD with administrative privileges first.
Start --> type CMD in Search box --> Right click the CMD 'shortcut' that appears at the top and select Run as Administrator.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
THANKS A LOT!!! Is there any way to completely delete the lexbsc service from the services list and from the computer so that it will never happen again? Thanks for all your help :D I thought I'd NEVER get it fixed
Also, I'm trying to uninstall lexmark from my desktop computer but it says that I can't because I have to wait for the printer to stop printing...that printer hasn't been connected in MONTHS. AND, I have a new printer installed and connected to it but it doesn't have any pending print jobs. ???
The *new* printer has no pending jobs, or the old printer has no pending jobs?
And uninstalling the Lexmark drivers should uninstall the service as well.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I don't think either has a pending print job. If the new hp printer did, it would be printing. The other one's not hooked up. I can't un install it. I also got a message once I got the spooler working that said something like the subspooler app has stopped working but windows will tell you when it's running again or something like that. What is this about?
Hmmm - If you have access to the old printer hook it up so you can uninstall the software. If not, go to Drivers and Downloads - Lexmark and find your printer model and search for a driver cleaner utility to remove the driver.
As for the last error about the print spoiler closing down on you, well, that could be part of the reason why the Lexmark drivers are not uninstalling. It could also be a malware infection.
First things first - have you tried uninstalling the Lexmark software as administrator?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I'm not sure if I've tried uninstalling as an administrator? How would you do that? I just tried uninstalling it by going to control panel and then add/remove programs.
I contacted a live support tech agent for lexmark and got that problem solved. Now I just wonder what that weird error message meant on my laptop after I fixed the print spooler. My laptop prints to my desktop computer now so that's all I really care about. And the Lexmark printer is now uninstalled on my desktop computer. Thanks again.
actually, I have another question. When I shut down my desktop computer, it doesn't ever fully shut down. In stays on the "Windows is shutting down" blue page and won't go any further. Is that something I can fix through drivers or whatever?
Start --> Programs --> Lexmark directory --> right click on the uninstall link there (if it is even there - it might now be....)
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
? I'm confused. All the lexmark stuff is fixed but I was also needing help with my desktop cuz it doesn't shut down all the way when i shut it down so I was wanting to know if you knew how to fix that.
Hmmm - not sure on that - have a look at our tutorials while I look around for an answer
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
