9600GT SLI problem
Axe
yesterday i bought vista basic x64 and i installed all updates and all drivers, and then tried to enable SLI from Nvidia control panel i hit apply and it said to switch to SLI multi-GPU some applications needs to be closed. would you like to close those applications now? so i clicked yes then the screen went black i waited about 10seconds and it went back to normal but all that was left in the control panel was first-packet settings. im using latest drivers 175.19 any suggestions how do i get SLI working?
on my XP x86 i had no problems setting SLI
Hi, i have experienced the same on my brothers pc,when enableing sli the screen went black when its supposed to show you the new option screen and text " would you like to keep this new settings" but nothing. So we tryed one more time and when the screen went black again we hit enter to acept new setting even if what we saw was stil a black screen,then we unplugged the DVI contact while pc stil running and checked all other dvi contacts on both cards and i worked on the 2nd dvi in sli.
Mabye its like that with your pc too.
Good luck
    Fred Narvåg Model nr 007
    Core 2 Quad Q6600@3,0Ghz 24/7
    Asus Rampage extreme
    OCZ DDR3 pc12800 8gb
    Asus GTX260 896mb ddr3 Top
    SoundMAX integrated Digital HD Audio
    Asus 22" lcd 2m VK222
    2x 74gb S-ata WD raptor systemdisks in raid o(stiped) 1x 320 gb storage + 2x160 gb storage
    NorthQ 1000W
    Cooler Master CM Stacker
    Noctua NH-U12P
    Simple standard optical
    Simple standard keyboard
    4mb/s down 0,6Mb/s up
