Hi There!
Since installing the latest Nvidia Graphics Driver 175.19, I've had a bit of an issue when I go to Restart or Shutdown my PC.
After I click-on Restart or Shutdown, the Logon screen appears, then it goes back to the Desktop Screen, then back to the Login screen and Restarts or Shuts Down correctly.
I'm not sure whether it may have something to do with the Task Scheduler (and Windows Sounds possibly), but any help from anyone would be very much appreciated.
Warmest Regards
Neil
Warmest Regards
Neil
- Custom Built
- Intel Core i7-920
- Gigabyte GA-EX58-UD3R
- 8GB Kingston DDR3 1333MHz (4 x 2GB)
- Gigabyte GV-N26OC-896H-B
- N/A - On Board via SPDIF
- BenQ 24" E2420HD
- 1920 x 1080p Full HD
- Western Digital 1 x TB Sata 1 x 320GB Sata
- PSU
- Zalman 1000 Watt
- Case
- Antec Twelve Hundred
- Cooling
- 1 x 200mm fan, 6 x 120mm fans, CPU & GPU fan
- Bluetooth Logitech MX 5500 Laser
- Cordless Logitech MX 5500 Revolution
- Other Info
- 2 x Liteon DVD Burners Sata
