2 questions: BOOTMGR is missing problem...
Nodijo
Hi. Please forgive me if this is the wrong place to post this, I searched and read the other threads before posting and didn't see anyhting in the other topics either, although being new, I'm still finding my way around. I am new to Vista, I must say I really like it, if I could get myt problem resolved, I'll be VERY happy. I am a Graphic Design major, so my computer is my lifeline so-to-speak. When my son did this build for me we did it in stages and I'm pretty proud of where we are. However, huge issue for me- Vista will boot just fine IF I leave the original installation disc in the drive, if I remove it and try to boot it, I get the message in DOS "BOOTMGR is missing press CTRL+Alt+Del to Restart" this is very annoying. Anyone know how to 'fix' this problem or do I just shell out $60.00 to the computer techs that said they could fix it? My son told me to check here first.
My system is:
Built by my son "Mr.B"
Windows Vista Home Premium x64
ASUS P5N-E SLI
Core2 Duo E6300
4Gb XMS2 800
(2 150Gb RAPTORX in RAID 0)
250Gb SATA2
(2 eVGA 8800GT in SLI)
Antec SmartPower 500watt
Acer X191W widescreen monitor
My system is:
OS: Windows Vista Home Premium x64
Intel Core 2 CPU 6300@1.86GHz 1.87GHz
4 G RAM
NVIDIA STRIPE 279.47G (2 150G RAPTOR drives)
250G Storage Drive
NVIDIA GeForce 8800GT SLI
Welcome to the Vista Forums :party:
I found one solution related to the bootmgr issue from a Microsoft source. The error message is different, but it might be related to your situation. Take a look at Microsoft's solutions for bootmgr problems and see if they work for you. The link to the Microsoft solution is: Error message when you start Windows Vista: "The Windows Boot Configuration Data file is missing required information"
Let us know if that works for you.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
:):party: YAY!!! Thanks so much Joe, I went to the link and that worked. I did go ahead and take it in and have a tech check just to be on the safe side and he disabled the usb boot option or something like that...I'm not a techy, but I think you'll know what he was talking about. Anyway, 1,000 thank yous!!
