Hi everyone, I´m new here. Signed up thanks to my dysfunctional, three year old Packard Bell iXtreme computer. I really hope one of you can help (although more than one of you would be great too!). I´m going to list the problems I have had with it and include the spec at the bottom. In terms of experience I´m not very computer savvy and when I got the black and blue screens I didn´t know what to do so Ididn´t follow their instruction. Also, I wouldn´t really like to open the thing up but would probably do so if required, after a lot of deliberation.
CurrentProblem:
· From March 2012 the computer hasn´t been able to boot. When I press the tower´s on button, the electricity kicks in straight away, it beeps once, the LCD screen stays on standby and al lthe lights in the keyboard light up. Then the situation just hangs. The toweris still running but there is nothing, I don´t even get an option to do system restore or view the BIOS. I am waiting for recovery disks in the post but I know the machine also has a recovery partition which I can´t access due to the BIOS not loading, I imagine!
Black and Blue Screens Jan – March 2012 (the slide into oblivion):
· 1st error message: black screen(early Jan 2012): "windows failed to start. File is possibly corrupt. Its header Checksum does not match the computed Checksum" (see attached photo). I did a system restore. Everything was working again.
· Mid Jan 2012 started receiving blue screens "DRIVER_POWER_STATE_FAILURE"plus long error codes (see attached photo). I restarted the computer and did asystem restore. This worked but the computer got progressively slower and more unstable.
· Up until mid Feb 2012 computer had a number of problems; I kept getting the DRIVER_POWER_STATE_FAILURE message, it would freeze for half an hour at a time at a click of the mouse (whole system), I would then restart and use system restore on many occasions. The CPU memory usage would just spike around these freezes (I had Norton 360 alerts) and everything would grind to a halt so I tried defragging the computer, disk cleanup and virus scans with Norton but the problem persisted. I was doing system restores often. At times I had to manually restart the computer several times just to get a system restore screen as the "Checksum" message would loop everytime I pressed there start button and also sometimes another message I didn´t write down like"boot" and some other letters.
Possible contributory factors:
Moved house 3 months prior to probs, comp survived ordeal by boat and van for a few days atthe hands of Spanish removal men. The computer was working fine straight afterand for three months or so however.
Wouldn´t wake up from sleep frequently. Would have to unplug then restart to get it working.
SPECIFICATIONS:
Ixtreme X6617 UK
Intel Core 2Quad Q8200 Processor
4GB DDR2
640 GB SATA Hard Disk
(15GB allocated for recovery system)
nVidia GeForce GT120 1024MB to 2303 MB + HDMI
DVD RW R9
Microsoft Windows Vista Home Premium SP1 (updated to SP3 online I think)
Microsoft Office 2007
Norton 360 Internet security
I contacted PackardBell who just said it sounds like a hardware problem but didn´t help any further than that. Could anyone recommend me a solution to this problem? I would be very grateful for some advice. I hope that my computer isn´t ready to go to silicon heaven yet!
Many thanks,
Jules 103
CurrentProblem:
SPECIFICATIONS:
Ixtreme X6617 UK
4GB DDR2
DVD RW R9
Many thanks,
Jules 103
- Packard Bell iXTREME X6617 UK
- Intel Core 2Quad Q8200 Processor
- nVidia GeForce GT120 1024MB to 2303 MB + HDMI
- 640GB SATA HArd Disk (15GB allocated for recovery system).
