BSOD and CRCDISK.exe problem
malaya
Good Morning heres an issue we have with a Vista Gateway laptop.
My roommates Gateway laptop 2 years old had a bunch of viruses last night including WildTangent and Mywebsearch. After doing a virus scan with malwarebytles we restarted the computer and after it does the windows boot the screen goes black with only the pointer showing.
We tried the following:
Restart back to last known good configuration- Not working
Removed battery and pressed start button for 60 secs and then connect everything again still not working
Safemode- Still black screen
Safemode error- Stops after crcdisk.sys
Disk repair/system restore- does not say any error
We don’t have the Vista CD for this to do a system recovery
Asa note the latop was also very hot. Both on the latop side and the AC adapter side. I dont know if it fried the motherboard, but we still get to the Windows logo screen and does allow us to do an F8
Please help. Thank you
Thank you for the reply. The error is not a Blue Screen and unfortunately i can even install anything onto the laptop since it only allows me going up to the commands in F8 but goes striaght to black screen.
If you read the Subject of your post, you said that it could be a BSOD. I will read it again and try to give appropriate help
