Laptop running like garbage.. please help
expy45
Please help out a noob.. my computer freezes about every minute for about 10-15 seconds and its driving me crazy.. Its only been doing it for about 2 days now
    HP G60 Notebook PC
    Pentium Duel Core, T4200 @ 2.00GHz
    3.00 GB
First make a full scan with your anti virus
Then download and make a full scan with malwarebytes. If negative follow these guidelines
Here are my solutions to freezing, and an excellent article, which I hope is of some help
Go to search type device manager and look for any yellow warning markers
Download and run malwarebytes, a full scan after you update
Run antivirus scan
Check memory with memtest86
Make sure that you are not over heating.
Try in safe mode; report back if it works properly.
Try a clean boot
Make sure PSU is working properly
If overclocking, restore to original
Test hard drive at company website.
Test in safe mode, does it still happen?
Try with clean boot..
http://support.microsoft.com/kb/929135
http://www.geekstogo.com/forum/topic...ing-memtest86/
http://malwarebytes.org/
http://www.almico.com/speedfan.php
http://ezinearticles.com/?Troublesho...blems&id=39981
Run antivirus scan
Try a clean boot
Great post rich, but your memtest link is wrong, I think you may have copied the text of another hyperlink, not the link itself as the url you have specified has "..." in the middle of it. The memtest guide can be found here:
Guide to using Memtest86+ - Geeks to Go Forums
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
TY Tom that is what the forum is all about, members helping each other. You dont have to wait for an OP to offer help.
I had an old link that I will change.
Indeed it is and I'm glad I could help Rich! Thanks for the rep :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Would i be able to do any of this in safe mode. I cant get anything to work anymore in regular mode
    HP G60 Notebook PC
    3.00 GB
Try in safe mode
I originally ran mcafee before i was unable to get back into regular mode which was negative but now i am unable to get onto the internet to download malwarebites
I opened up device manager (in safe mode) and see no yellow markers
and again no internet so i cannot download memtest
Now i restarted and went to the startup menu
Here i selected "start up test" which ran a system memory test (not sure if same as you were referring to) which Passed
Then ran a primary hard disk self test which says:
#10008 - Replace Hard Disk 1 rent test titem
SMART check
SMART Hard Disk Passed
Then I ran a "run in test" and got all the same results as the start up test
My diagnostic Log shows
Result:
0305
0303
And thank you very much for you help by the way
    HP G60 Notebook PC
    3.00 GB
Can you do the clean boot that I mentioned in my first post? If so do it now and report back.
So it took a while but using the clean boot i finally narrowed it down to "recovery service for windows" being the cause of my problems. What should i do to fix that?
    HP G60 Notebook PC
    3.00 GB
Ok well i was still having issues with my system running slow anf freezing often so i decided to back everything up and do a system recovery to just clean out my computer and start from scratch. Upon start up i hit esc and select system recovery. Under the recovery manager i select no to "would you like to launch microsoft system restore" which returns to an earlier point in time and yes to "system recovery" which restores to original factory shipped condition
From here it begins Factory image recovery "reformatting the windows partition of your hard disk drive" and "reinstalling original content"
Once recovery is complete i click finish to restart the computer
Next it starts the software installation which stops about a quarter way through and restarts again and says "please wait while windows setsup your computer"
Here i recieve an error saying "windows setup encountered an internal error while loading or searching for an unattend answer file"
After that i force restarts again and says its setting up again and shows the error again and just gets stuck in this loop
    HP G60 Notebook PC
    3.00 GB
