Install Crash Problem... Please Help
MattHatesVista
I purchased a HP Laptop with Vista Home Edition SP1 32bit and recently I was recovering the laptop to factory default settings. At the end of the restore the computer crashed before the screen to enter your first account name appears. Now when i start the laptop it will shut off before the log in screen appears. Also, i have ran the hp factory restore disks and the same problem has happened before. The error is as follows:
"The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click "OK" to restart the computer, and then restart the installation."
I have tried to redo the installation about 15 times and the same message appears. My knowledge of computers is above average and any suggestions/idea's would be greatly appreciated.
Thanks,
Matthew
Can you get to system restore in safe mode?
When you do the restore 16th attempt? Do a destructive restore. That is to say, re-format the disk too.
This will reset the restore process back to the begining & start again instead of continuing the bad recovery.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Ok well it crashed in safe mode. And I am unable to format the hard drive because i am unaware how and the computer will not stay on long enough for me to try. Any suggestions on how to format the hard drive?
Thanks,
Matthew
