Blue screen, sound issues and programs stop responding. pls help me
Zigg85
Hi guys, I'm new to this site.
Over the past week i have started to have some pretty major computer problems, and i am certain i didn't play with any settings or download anything that could cause them, not intentionally at least. A few of the symptoms are
- Blue screen, messages vary, Irql not less or equal, memory insufficient and maybe 1 or 2 others. Blue screen occurs at random times sometimes it may happen after a few hours, and sometimes directly when it is restarting from a blue screen.
- A window pops up at various times, telling me that a program has stopped working e.g. Windows Defender
- Firefox crashes frequently, on that note so does Internet Explorer, flash player stops working if streaming something and will work for a short period of time if i reset web page.
- Sound stops working and makes a really loud stuttering sound sometimes at start-up when you hear the login tune, other times its fine for a while plays music for 30mins before it dies.
Here is the unexpected shutdown message:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 3081
Additional information about the problem:
BCCode: a
BCP1: C08027C6
BCP2: 00000000
BCP3: 00000001
BCP4: 822E2C22
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini112310-04.dmp
C:\Users\Matthew\AppData\Local\Temp\WER-44226-0.sysdata.xml
C:\Users\Matthew\AppData\Local\Temp\WERBC3C.tmp.version.txt
I would really appreciate any help i can get with this, I've been to heaps of forums, run a ton of scans with AVG and PC tune-up, even tried sfc/scannow in CMD, didn't even make it to 50% before another crash.
I'll attach the minidump files on the next thread, thanks
    HP Compaq
    AMD Athlon 64x2 Dual Core Processor 5200+ 2.60GHz
    3.00 GB
    NVIDIA GeForce 8400 GS
    Sony Bravia 40" LCD TV
    1280 by 768
    ST336032 OAS (D) Factory Image 8.67/10 GB used ST336032 (C) 195/325 GB used
Here are the minidump files, I only uploaded the latest 4 as there were 24 in the folder, if more are required just let me know :)
    HP Compaq
    3.00 GB
    1280 by 768
Sry forgot to upload these files.
Compaq purchased 2008, Windows Vista Home Premium 32 BIT, installed before purchase.
    HP Compaq
    3.00 GB
    1280 by 768
