system configuration data updated ERROR,--Need a solution I have a
fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1.
I turned it on and beeped twice (beep, beep) and gave me an error
message that reads "system configuration data updated ERROR, system
configuration data read error"
Press f1 to continue f2 to enter set up.
I pressed f1 and it sent me to another blank page that reads.
Windows failed to start. A resent hardware or software change might be
the cause. To fix the problem:
1. Insert your windows installation disc and restart computer
2. Choose your language settings and click next,
3. Click ?repair your computer.?
If you do not have the disk, contact your system admin. Etc
Tried the repair disc, tried reinstall from Restore DVD still get the
same message.
Tried the bootrec.exe/fixmbr (worked)
Tried the bootrec.exe/fifixboot (Worked)
Tried the bootrec.exe/Rebuildbcd
Tried reseating the memory and hard drive.
Still at the same point. Even tried to install XP over it but never
could get it to go.
Now I am back to where I started. I already replace the hard drive so i know is no that I think this is a boot problem.
what can I do???
same message.
could get it to go.
what can I do???
