startup repair problem HELP
nero1994
HI EVERYONE
i have vista home premium 32bit and i don't know why but i can't start it anymore.
it hapened before and i used the dvd and startup repair and it works
but yesterday when it hapened again in startup repair there is a message says
startup repair could not detect a problem
if you have recently attached a device to this comuter remove it and restart..
but i have nothing attached and i repeat that like 5 times and nothing
if there is other way to fix that without format my pc please tell me
i have importent files on it in (c:/) drive and i don't want to lost them
please i realy need help
What error message do you get when you try to Boot into Windows?
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Type c: then type chkdsk /f on command prompt at the recovery DVD. If that doesn't work try System restore - system restore only affects on system files - not your personal files.
    Nirv Pro SLI (shipped to NZ)
    Intel Core i7 Extreme 980X (Six-Core) 3.33GHz
    Gigabyte X58A-UD5 - SLI, Crossfire, SATA 6Gbps & USB 3.0
    12GB G.Skill Ripjaws High Performance Low-Latency DDR3
    2x NVIDIA GeForce GTX 480 3GB GGDR5
    N/A
    23" Samsung XL2370 Monitor and 23" Benq V2410 Monitor (extended monitor)
    1,920 x 1,080 (on both monitors)
    2TB Western Digital Caviar SATA (7200rpm) 600GB VelociRaptor SATA (10000rpm)
    Silverstone Strider Plus Modular 750-Watt SLI
    Corsair Obsidian 800D System Chassis
    Arctic Cooling Freezer 7 Pro Rev. 2
    Razer Mamba Gaming Mouse
    Logitech G19 Gaming USB Keyboard
    Max - 1.8MB/Sec (DSL) provided by Telecom NZ
    iPhone 4 Black 16GB, iPad 32GB WiFi+3G, iPod Touch 2nd generation
for the (c: the chkdsk/f) it didn't work it says failed and something like that and for restore system it didn't work either it says no restore point and when i click system protection to create one it says
your compiter is running in a limited diagnostic. if you use system restore in this limited state, you cannot undo the restore operation.
and then nothing
HI EVERYONE
Okay Do you have an Installation Disk and could Burn this ISO to a Disk this is Ubuntu 10.04 so you can Recover your Data
See Download | Ubuntu For more Information
And then Boot into this CD and recover your Data
After that if you have an Instalation Disk
See http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html If you have an Upgrade Version
Or see http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html If you have a full Version
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
