Okay so I know a little about computers but not enough to figure this out so I thought I would try this forum out....so basically what happened to me was i wanted to do a system restore to a previous point and windows wouldnt let me until i performed disk check but everytime i tried to perform disk check after startup it wouldnt work so i thought i would go into recovery console with my windows cd but i didnt have my windows 7 cd on me so i used the hp disc that came with my laptop and once i put it in and started up my computer it started to put it back to factory condition by formatting the drive so when i saw it was formatting it was still at one percent so I freaked and popped open my drive and then everytime i tried to boot it would say missing boot manager files and i basically tried everything to fix that but it didnt work so i just ended up installing windows 7 again on my separate internal d drive and now my c drive that used to contain windows 7 is all unallocated space and i was wondering if there was any way i could possibly recover this drive back to its original state before it became unallocated since it was only the boot files that were deleted?
Thanks
Thanks
