Ok, heres what happened:
Vista got stuck on the loading splash screen with the green bar moving along the bottom. Left it for 15 minutes & didnt budge.
Reset the PC & tried again - same thing.
So, I booted of a recovery disk & ran CHKDSK /R.
Found a few errors & repaired them & rebooted.
Now, Vista didnt boot at all & i just got the message:
'Operating System Missing'
So, I booted from a Vista disk (Ultimate)
Chose repair but was greeted with an empty 'System Recovery Options' box.
Clicked next anyway & got to the repair menu.
Select 'Startup Repair' & it went off on its merry way for about 3 minutes but then reported back that there wasnt any operating system to repair.
So, went back to the repair menu & went opened up the Command Prompt.
Went through the usual boot repair methods:
bootrec /fixmbr
(this operation was completed successfully)
bootrec /fixboot
bootrec /ScanOS
(Successfully Scanned Windows Installations. Total Identified Windows Installtions: 1
[1] D:\Windows
This i thought was odd, why D: ? normally Vista is on C:
Anyway, carried on:
bootrec /rebuildbcd
(Successfully Scannec Windows Installations. Total Idenified Windows Installtions: 1
[1] D:\Windows
Add installation to bootlist? Y, N or All)
Selected Y & then got this error message:
'This Volume does not contain a recognized file system. Please make sure that all required file system drivers are loaded & that the volume is not corrupted'
bugger.
I evern tried this:
del d:\boot\ /f /s
bootrec /fixmbr
bootrec /rebuildbcd
got the same error.
I can see the harddrive fine. I can even browse the files & folders on the drive within Command Prompt, so its there & not corrupted.
I just cant fix the boot problem.
Anyone got any ideas?
btw - reformat or upgrading to Windows 7 is not viable at this moment in time.
Cheers
bootrec /fixmbr
bootrec /fixboot
bootrec /ScanOS
[1] D:\Windows
Anyway, carried on:
bootrec /rebuildbcd
[1] D:\Windows
bugger.
I evern tried this:
del d:\boot\ /f /s
bootrec /fixmbr
bootrec /rebuildbcd
got the same error.
Cheers
