A few days ago, after a windows automatic update, my computer is no longer able to boot. It returns this message: ...\Windows\System32\Drivers\zeqpju.sys system file missing or corrupt. I have tried to do a recovery several times with no luck, I've tried everything I know to do in safemode and dos, I've even tried every method possible on the spotmau cd, but I still get the same bs!
Any ideas would be greatly appreciated. Also, I cannot locate any information concerning the zeqpju.sys file...do you know where I can get this file, so that I can try to replace the matching corrupt file on my system?
Thanks...
Thanks...
- Q2Designs Model No:MS-10342B
- Dual Genuine Intel(R) T2400 @ 1.83GHz, 1826Mhz, 2 Core(s)
- MICRO-STAR Model #: MS-10342B
- 2GB
- Intel GMA 950
- Realtek ALC882D
- Internal HDD 60GB External HDD 250GB
- 15Mbps
