BSOD, DRIVER_IRQL_NOT_LESS_OR_EQUAL, need help :(
Kastekniv
Hello there everyone!
Im having a huge issue with my computer. It will boot fine the first time after say 10 minutes, then will enter windows and either freeze in a warped screen or reboot or restart on its own within a short period of time (seconds perhaps). On restart it stops in a black screen with a blinking space. If i enter safe mode it will reboot after a while again and i get a BSOD saying...
Tech info reads:
*** STOP: 0x000000D1 (0xCFF30023, 0x000000FF, 0x00000008, 0xCFF30023)
And thats all, no other information given.
I even reformatted my hdd, which appeared to get rid of the issue, but it appears to rear its head in some update perhaps within half a week and i would not like to reformat again as i will lose important software and files. As far as im aware i have a fully updated BIOS and driver software.
I have an ASUS X59SL.
# Processor - Intel Core 2 Duo T5800 2 GHz Dual-Core
# RAM - 3 GB - DDR2 SDRAM (maybe SATA)
# Hard Drive - 320 GB
# Operating System - Microsoft Windows Vista Home Premium
# Screen - 15.4 in TFT active matrix 1280 x 800
# Optical Drive - DVD±RW / DVD-RAM
# Graphics - ATI Mobility Radeon HD 3470
I have no idea where to even start to repair this, and i can't send it off as warranty is gone and getting it repaired could be a lot of hassle for me as i need my compy working now. Im currently using a public computer to write this. Any method of repairing or diagnosing this problem I would be immensly grateful for!
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
I dont have a Minidump folder, or know how to get one.
But even if i did, i can't stay on my compy for more than a minute to upload it. It just reboots or pops up that BSOD.
But say if i was lucky enough, how do i get the minidump folder or .dmp file?
Boot into Safe mode.
Right click on "My Computer", click on Properties, click on Advanced tab, click on Startup and Recovery Settings.
Make sure that "Automatically restart" is unchecked, and that "Small memory dump" is selected under "Write debugging information", and that "Overwrite any existing file" is unchecked.
Then upload the .dmp file the BSOD creates. If the upload doesn't work, change the extension from .dmp to .txt and try again.
It would also be helpful if you could download http://www.vistax64.com/tutorials/176785-vistaforums-sysinfo-tool.html, run a complete run, export to a file, and upload.
I recognize it crashes pretty quickly, but see what you can do.
We'll be here.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
