blue screen of death problem recurring
hi vista forums,
when i start up my com puter , everytime when i get to the stage where there's a black screen and a little bar where it loads, suddenly i get a blue screen that flashes for less than a second, not even enough for me to see what it says, after that, my computer restarts, and then i can either start windows normally or launch startup repair, i did the startup repair, i did the system resotre, then i finally logged onto the computer, but then the next day, when i opened my computer, the blue screen happened again...
I really need help, this is extreemly annoying.
    Compaq Presario
    AMD Phenom-64 8750 (2.4GHz)
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
poolwizard-
C:\Windows\Minidump\
Zip and post any files found in that folder.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
Right click on "My Computer", click on Properties, click on Advanced tab, click on Startup and Recovery Settings.
Make sure that "Automatically restart" is unchecked, and that "Small memory dump" is selected under "Write debugging information", and that "Overwrite any existing file" is unchecked.
Next time you get BSOD, upload the Minidump file you should find in the C:\Windows\Minidump folder.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Ed
thanks, i tried it, just done the small memory dump thing, now if i get the error tommorow, i'll inform you :)
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
uhhh.. just wondering.. when i get the BSOD, usually i cant get onto my computer because of that.. and i have to do system resotre via the startup repair thing... just wondering that if i done that, would the minidump thing be restored back?
i'm totally unsure about that, due to my lack of computing knowledge, please tell me if it's true or not.
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
I think if you were to restore your computer to an earlier point you would lose the minidump file.
That is probably why the folder was empty the first time you checked it.
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
When you get the BSOD can you boot up into Safe Mode?
If you can, do so, and save the minidump file into one of your Temp folders before you do the Restore. Then you can upload it from there.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
nah the reason why i didnt have any before was because the create a small file (64k) or something like that was not on
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Ed
what do you mean by saying "When you get the BSOD can you boot up into Safe Mode?" do you mean can i boot up safe mode when the bsod occurs or what? i suck at computing terms.. i think you'll need to help me out
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
The next time you get a BSOD, restart and boot up in Safe mode with Networking before you do the restore; then the minidump should be there and you can save it to another directory and upload it.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Ed
ok thanks, i 'll try that
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Ed
ok i just did it... got the minidump file.. what now?
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
ok i just attached it, it's zipped and stuff, please check it out :)
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Hello poolwizard,
Here are the results of your bugcheck.
STOP 0x0000007E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Usual causes: Insufficient disk space, Device driver, Video card, BIOS, Breakpoint with no debugger attached, Hardware incompatibility, Faulty system service, Memory, 3rd party remote control.
Probably caused by : acpi.sys
The first thing is to replace the faulting driver which is acpi.sys
Use the tutorial below to extract the file and replace it.
http://www.vistax64.com/tutorials/261616-extract-files-vista-installation-dvd.html
Have you added any new software/hardware ?.
How much disk space do you have ?.
What third party software do you have ?.
Replace the driver and we can go from there.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hello poolwizard,
umm... i looked at the link ,i'm not even sure if i had the disk given to me when i bought the computer..
also i have like 640 gb hard-drive, about.. 450 left.. recent hardware would probably be.. uhh... malwarebytes update and.. tuneup utilities 2010 ( got a key for it from youtube) and for third party software.. probably just GTa IV which i download like... 2 days ago
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Hello poolwizard,
poolwizard-
If you do not have the Vista Recovery Disk the came with the computer, you can make one:
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
Un-install the tuneup utilities program.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hello poolwizard,
poolwizard-
on the link where you create a disk.. on step 16, i cant find my retail vista installion disk... and by the way, the last two nights, the computer booted without an error, then the BSOD happened again.. :@
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Then you need to use Option One in the link to create it.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
